SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
SOURCE: feed dogs will not raise, I have lifted the
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
