SOURCE: Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
SOURCE: I have a PSL33U-03W02K need to reload back to when
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the
hard drive then follow these steps to restore your Toshiba to the Out of the
Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button
once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system
recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.
6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.
Follow the prompts that appear on the screen to set up the laptop's date, time
and language settings.
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your
recovery disk or the original Windows operating system DVD
into the Satellite's
CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first
few seconds while it is starting up, press and hold the F12 key on your
keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to
press "C" to boot
from the CD-ROM). The screen will display boot for
this boot up session only.
3 Use the arrow keys to navigate. Select the
CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this
setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen
instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first
few seconds while it is starting up, press and hold the F8 key. This will begin
the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate
the menu. Move the keys to select "Repair Your Computer." Press
"Enter."
3 Select your language and keyboard; click
"Next."
4 Select your Windows user name from the
drop-down menu. Enter your password if required. Click "OK." This
will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow
the onscreen instructions. The Toshiba Recovery Wizard will delete all existing
data on the hard drive and reinstall Windows.
Hope this helps!
