Believe perhaps the receiving part of the Tele is not functiong.
I saw your i.d and related a bit, I own the original Mac which is still working and several other computers including a new Intel iMac (Not as good as power pc in my view!).
Anyway, I digress..:
Folk:
We think something is amiss with the receiver part of the television. My mother (who's quite disabled) lost the remote. I have tried, literally 5 other Universal Remotes, that work on other TV's but NOT the ORion.
THe light on the TV doesn't even flicker.
Is there a manual method to ensure the system is capable of receiving a signal?
THis is to say the least, quite annoying, as my Mother cannot get up to change the channels or volume.
It's just over a year old and has not been abused.......so any advice would be GREATLY APPRECIATED.
Does any one know if this system is capable of Microcode updates??
feel free to write; [email protected] or my number is 518-261-7106.
Thanks again...
Does anyone have any ideas? I wouldn't mind paying for the PAP offering, but I suspect, unless there is a microcode download it is a physical equipment problem?Does anyone have any ideas? I wouldn't mind paying for the PAP offering, but I suspect, unless there is a microcode download it is a physical equipment problem?
I greatly appreicate the response and especially knowing where to order it.
However, my concern is the 'reception indicator light' on the TV does not light when trying various functions manually nor over 4 universal remotes to manage the TV (but they did work on a Panasonic DVD Player and Sanyo VCR).
So my original concern is the 'receptor signal detector unit' (or whatever it is called), 'fried' in the TV and is there a method to detect that other than order a new remote?
Your advice is greatly appreciated and if all else fails I may have to resort to ordering a new remote, but it would be GREAT to know the remote is Truly the problem.
Thanks!!
Gary AlpertI greatly appreicate the response and especially knowing where to order it.
Thanks!!
Gary Alpert
You can't post conmments that contain an email address.
Never heard of this brand of saw. A Google search indicates that MacAllister only makes big earth moving equipment. Otherwise, most saws have an appropriate washer and retaining clip that holds the guard on. And you'll need the original spring to return the guard to the closed position every time you use it. Then there are two shaped washers that fit on the armature that have a 5/8" shoulder to fit a normal saw blade. Finally there is the nut that holds everything on. Hope you didn't lose all these parts. If you did, go to eReplacementparts.com and and enter your make and model. If they don't have what you need you might be plum out of luck. But a new saw.
Do other CD's that work in your CD player still? If they do then I am lead to believe your CD's might have got some good scratches on it. Perhaps have them resurfaced and try them again. If no CD's work I would suggest a CD lens cleaner disk and see if that helps. If still no CD's at all will play then you may have knocked your lens out of alignment a bit. That would have to be addressed by a tech. Good luck.
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
If you go to www.searspartsdirect.com and put in the model number of your saw you should be able to get one there. I don't believe that is the correct model number of your saw. Perhaps that was the model number of the motor. Does it look like this one?
Sounds like a bearing is shot and rattling up the works there. Rock the blade back and forth and see if there is any play in it, check the bearing at the other end of the shaft. Is this one of those skil saw motor saws? Or is the motor hanging down below the blade? Need to know that before I can tell you what it is.
You can download Tele Atlas updates at their map store here-
http://navigation.teleatlas.com/en/shop/. Since the Nextar is
relatively new, there is not a link for that brand on Tele Atlas's
site, but for best results try their US customer service. Numbers were
a bit hard to find but here are their US numbers-
http://www.teleatlas.com/WhyTeleAtlas/ContactUs/TheAmericas/index.htm
They should be able to tell you which update will be compatible for
you, and its as simple as sending your new maps to your SD card once
you download
I believe that camera only works with firewire. You might want to check with Canon to see if there is compatibility problems with Macs. I know it works on Windows computers.
i have the new ROM 1.10.10 ENG, i dont have any thing such as above. Trust me. Oh my model is 1940, a really nice toy bought in HK!
i saw a similar topic before. but it turns out on my 1940, it is still the same old thing, the notify.wav for email notification works.
Thanks!!
Gary Alpert
