Okay now I have a new fuel pump and a new relay, I turn the key and it will start right up. Run at normal high idle, then kick down to normal idle speed, then stall, and then it wont restart. Let it sit a few hours and it will do the same thing again. Fuel pressure regulator is working as far as I can tell. I have been chasing this issue and getting nowhere fast. Can you help??
Might sound a little basic but check your fuel filter you didnt say if it was or is fuel injected
Have you hooked a fuel pressure gauge to it?
I had a 93 ford van that did this from a defective ecm. The ecm would go down and shut down the fuel pump relay.
It is the engine control module (engine computer). It is under the hood, stuck through the firewall, drivers side, below the brake booster. But I would suggest alot of testing before you throw one at it. It likely cost 150-200 dollars.
No, all you will see of it is the plug, it looks like a plug, plugging into the firewall. About 100 pins. with a 10 mm head bolt in the center. You have to unplug it and then pull it out of the firewall.
Yes, the fuel pump secondary code could mean the relay is bad or the computer is not sending the control to the relay.
Okay to get with both responses recieved I put a new filter on with the new pump, and it is fuel injected. I have not put a fuel pressure tester on, I had kind of passed on that as being an issue as it has run for up to 3 minutes before stalling, and then the pump simply wont even come on afterwards. I have a diag computer and usually when this happens I can run the fuel pump test and the relay clicks, but pump wont run. Today the relay didn't even click, so I changed the relay and it was the same so I checked the fuse, and it was okay??
ECM? what is the ECM stand for and where would it be located?? I am in no way a mechanic, but simply can't afford to not do the repairs myself. I hope it is either inside of the rear motor cover or somewhere easily accessed from the hood.. LOL Thanks, David
is that the aluminum looking finned box on the side behind the battery?
I have the OTC computer for 1993 and older GM, Ford, and Chrysler which gives me the following codes, 636 TOT Range, 114 IAT Range, and 542 Fuel Pump Secondary. Plus a code of Seperator 10???? Does this mean anything??
