A very generous friend gave me his RCA 61" tv when he upgraded. It's great, but I can't get it to tune from the antenna input. I think the problem is that it comes with "GUIDE Plus+ Gold" system which is supposed to "download" broadcast info 'n' stuff, which I don't think is available in my area (Tucson). I'd like to disable the GUIDE Plus+ Gold system, but there's nothing in the manual about how to do this. The manual does say that I won't get the "Signal Type" submenu to the "Channel" menu if the GUIDE thingy is enabled. I want to believe that the guide system has control of the antenna jack, and that if I could disable the GUIDE system and get that submenu, I could get the antenna jack to appear as a selection and then get the tv to do an "auto channel search" of my local broadcast stations over the rabbit ears hooked up to the antenna in jack. As it is, Auto Channel Search sees nothing. Thanks in advance for any advice.
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
input source selected to DTV
may need to tune tv in settings channel auto tune.
Depending on which of the many thousands of Television models in existence your TV could be ???
it might be an analogue only receiver.
Hint: giving a make and model number for your tv would be very helpful in answering this question.
If it is Analogue only you may need to use a digital TV decoder unit to convert Digital TV to Analogue TV . Check inputs available like RCA inputs as some decoders have RCA outputs or HDMI inputs ?
Hint: giving a make and model number for your tv would be very helpful in specific answering of your question.
to find out inputs available and if DTV {put in what make and model number } into search
on your mystery TV do an
Internet search :
{make} {model number} specifications
How To Connect a DVD Recorder to a Television: 1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables. 2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV. 3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV. 5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV. 6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing. 7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder. 8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record. 9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2. 10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
The first step to connecting a DVD Recorder to your TV is to
determine what type of connection you want to make between the TV
source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This
is usually determined by the outputs and inputs available on the DVD
If you have an older TV that only accepts
RF (Coaxial) input, then you would connect the RF output (a coaxial
cable) from your TV source (in my case a Cable Box) to the RF input on
the DVD Recorder. Then connect the RF output from the DVD Recorder to
the RF input on the TV. This is the most basic (and lowest quality)
option for connecting a DVD Recorder to any TV.
If you want to
To use
To use
Now
and viewing.
If
If you have a
I took the back panel off and noticed that one of the cooling fans was not working..... apparently the computer tells the tv that it will not be able to cool. I cleaned things using air and basically followed the wires for the cooling fan and wiggled them... lol.. works fine now
