An unused Raid Fly Ribbon rolled down my Roper dryer lint shoot. How do I get it out?
Remove those 2 screws attached to the top of the lint chute. Then grab the back and release the top in front on each side. Then remove the front and get the drum out. Here is my crappy video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore dryer
Take the filter out and remove those 2 phillips screws on the top.
Take the back off. Get the screws out the filter housing.Wiggle the housing over enough to remove the object.
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
SOURCE: Roper dryer gets hot and turns but the heat is
remove the front cover of the unit and make sure the dryer wheel is hooked and turning,while in there check for any pipe ductwork thats disconnected
SOURCE: it sounds like something has fallen down the dryer
I am guessing this is a kenmore/whirlpool dryer simply because of the problem. Yank out the filter,remove the screws on the top of filter housing. Use putty knife to pop top and then remove front. I have photos and manuals HERE
SOURCE: roper elctric dryer model RES7648EQ
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
