When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
on your desk top on the back of your tower there is a plug in for speakers just turn your tower around and you will see the insert for your speakers, good luck
With not all the speakers hooked up, it will definitly effect the sound. The unit is designed to channel different sounds to certain speakers. That's what makes you feel like "you are there" If you have lost the cords to the tower speakers, you can buy replacements. Go to where you bought the unit, a Radio Shack, or other store that sells home theater systems. Enjoy your system like it was designed .
Try doing an auto-calibration through your amp to check that all the speakers are correctly connected, if they are then try play around with the EQ. otherwise, chances are it's a manufacturing fault
make sure you plug get in the whole where the speaker icon is. also try using an other set of speakers to see if the problem is not the speaker cable. also clean it with a little cute-tip becareful not to leave any cottom in it.
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Probably a poor power connection either where the AC pack goes in to the wall (probably powerbar!) or where the plug from the power pack goes into the unit. Wiggle the various connectors to see which one solves the problem.
As a last resort you may have a faulty power pack (try ask a dealer or friend to test your system on their power pack).
do they need a power adapter to plug in?
