Garden Logo
Anonymous Posted on Apr 22, 2013
What is the spark plug gap specification - Garden
Curtis Sewell
Level 3:
  • Garden Master 7,482 Answers
  • Posted on Apr 23, 2013
Curtis Sewell
Garden Master
Level 3:
Answers
7482
Questions
Helped
1943221
Points
24946
Proper spark plug gap on 98 ford ranger 2.5L with 8 plugs
The proper spark plug gap for your 1998 Ford Ranger 2.5L with 8 plugs depends on the specific spark plugs you're using. Here are some recommended gap values:
Champion RC8PCY: Gap of 0.8mm.
NGK PFR6B-II: Gap of 1.1mm.
2answers
Spark plug gap for Murray Select Tecumseh Snow king 8/24?
The spark plug gap for a Murray Select Tecumseh Snow King 8/24 can vary depending on the specific model and year of the engine. However, as a general guideline, the spark plug gap for most Tecumseh Snow King engines is between 0.020 and 0.030 inches (0.5-0.8 mm).
To be certain of the correct spark plug gap for your specific model, you should consult the owner's manual or contact the manufacturer. The manual or manufacturer should have the recommended gap size and other relevant information about maintaining your engine.
Whats the gap on a spark plug for a 2008 buick lucerne 3.8
Ignition System Specifications
Application
Specification
Metric
English
Firing Order
1-6-5-4-3-2
Spark Plug Gap
1.52 mm
0.060 in
Spark Plug Torque
15 N·m
11 lb ft
Spark Plug Type
GM P/N 12568387
Spark Plug Wire Resistance
3000 ohms per ft
1helpful
I need the spark plug gap on NGK plug?
Actually no, What you need is the correct Plug gap for your specific Blower.
Most blowers have a gap of around .028". But you should check the specific gap for your Make and Model
1helpful
Spark plug gap 96 gov safari ACDelco platinum 41-942
Spark Plug Gap - AutoZone
www.autozone.com/.../specificationsMain.jsp?...Spark+Plug+G...
AutoZone2004 Mercury Grand Marquis 4.6L SFI 8cyl ' Specifications ' Spark Plug Gap.
AstroSafari.com • Spark plug gap size?
www.astrosafari.com/viewtopic.php?f=43&t=81409
Jul 27, 2015 - You're doing a '96? I think EARLIER 2nd Gen 4.3's used a .045" gap ; I believe it changed in 2000 or 2001 but don't quote me on that. All i'm ...Missing: gov
AstroSafariVans.com • View topic - spark plug gap question
astrosafarivans.org > ... > ENGINES GENERAL/PERFORMANCE
Nov 28, 2012 - 15 posts - ‎4 authors
My question is do I gap the spark plugs per 89 4.3 specs or do I use the 95 .... The vortec heads for a V8 chevy are 1996 and up however there ...Missing: gov
What is the proper sparkplug gap? - CarGurus
www.cargurus.com > Questions > GMC > Jimmy
CarGurusMar 16, 2013 - My Haynes manual and various places I've seen online say the gap is .045 inches ... spark plug gap for 1992 4.3 160 HP? ... Used GMC Safari".Missing: gov
[PDF]2000 GMC Safari Owners Manual - GM Extended Warranty
www.vadengmpp.com/owners-manual/gmc/2000-GMC-Safari.pdf
A gap tool is what you use to set the gap on your spark plugs...The gap is the tiny space on your spark plug that allows the plug to fire the engine. When you buy the spark plugs at the auto parts, the spark plugs come pre gapped for your specific engine. I usually check them to make sure.
What is the gape for the plugs"?"
for the 2.2 liter engine:
  1. Gap the spark plugs to 0.045 inch (1.1mm).
for the 2.4 liter engine:
  1. Ensure the spark plugs are gapped to specification: 0.042 in. (1.06mm).
for the 3.5 liter engine: Adjust spark plug gap to 0.043 inch (1.1mm).
Spark plus gap
AutoZone's online specifications page gives this message..."Refer to the underhood emissions label for specific spark plug gap information" They go on to say..."Caution! Gap is not adjustable on certain plug brands"
Top Garden Experts
Jay Finke
Jay Finke
john h
