I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
