Can you replace the plastic carb fuel inlet fitting on a briggs and stratton motor
SOURCE: i need to how to connect the throttle to the carb
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
SOURCE: My briggs & stratton will not start
i had a similar problem on a 20 hp v twin. there was trash in the fuel shut-off solenoid screwed in the bottom of the float bowl stopping fuel. It will come out without pulling the whole carb apart.
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
SOURCE: Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
