SOURCE: Do I use regular or premium gas for my '96 Honda VT 1100 C Shadow
You always want to use the highest octane gas u can find in a motorcycle engine .... 91 at least
SOURCE: stator removal honda
There is a tool that is used, it looks like a steering wheel puller or flywheel puller. Loosen the nut, a strap tool is handing to hold the stator still while you loosen the nut. Then using the removal tool, you pull this off. reassemble by tighting the nut. You should be able to get a puller at autozone in the loan a tool program. I hope this helps
SOURCE: 2002 honda vt 750 shadow spirit one cylinder won't fire what's the problems
Pull the plug out and test it on the frame. If no spark you need new plugs. If it does spark look at the plug. If the plug is black and wet it is getting to much fuel and flooding. You will need to adjust your carb's air to gas mixture.
