How to reassemble the blades on the Wahl Rechargeable Cord-Cordless HomePro PowerDrive Clipper XL 9550-500...there are 4 parts and i forgot how to put them back together?
SOURCE: reassmbling wahl product
Q. How do I align my blades?
A. ALIGNING BLADES
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken?
A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
SOURCE: I have a Wahl clipper Pro Series Rechargeable
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
