Sony Grand WEGA KF60DX100 60" Rear Projection Television Logo
Emmanuel Posted on Apr 16, 2013
Sky+HD box isn't a getting satellite signal - Sony Grand WEGA KF60DX100 60" Rear Projection Television
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
58
Points
My Sky+HD box isn't getting a satellite signal
2helpful
2answers
I do not have a satellite sisgnal
check power and tv in correct mode -then check alignment of dish --if good and no large storms in area notify sky of problem it may be box or programming
Why is my sky+hd box not getting a signal?
Bad dish alignment. Rain or snow blocking the dish. Leaves on a tree blocking sight of the satellite. Scaffolding/building works blocking sight of the satellite. Fault on the cables. Damaged or faulty LNB
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Sky+hd box isn't getting a satellite signal
have you checked the cables to the lmb ( dish ).... or take the dish cables out of the back of the sky box. wet your finger and put finger on to the centre and out part of the cable connector that some times works. faling that the sky box may need a factory rest or is damaged or the lmb has gone.
3helpful
1helpful
2answers
No signal being recieved
Sure the sat is getting power?
1helpful
4answers
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
4helpful
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
