For the last two days I am getting this message continuously popping up and down on my screen with details as follows : Network = green mark OK Speaker = green mark OK Microphone = green mark OK Skype = red mark ! I have tested my skype connection but could not find anything wrong with it I have also tested my quick cam and quick call usb speakerphone but this all works perfect,but this message keeps on popping up it realy drives me nuts.PLS help
This might be the effect of some spyware or virus attack.
Go to safe mode and run your antivirus/Antispy.
If it does not work, then reinstall the OS or recover from recovery disk if you have one.
It is at Facebook own will how and why they block their users...!
- you better create a new account because it is almost useless to deal with them for recovering your old one.... https://www.facebook.com/help/185747581553788/
Reasons Facebook disables accounts:
If your Facebook account has been disabled, you'll see a disabled message when you try to log in. If you don't see this message then you're probably experiencing a login issue. Get help logging in.
Facebook disables accounts that don't follow the Facebook Terms. Some violations include:
Continued prohibited behavior after receiving a warning or multiple warnings from Facebook
(*sometimes also WITHOUT a warning!)
-Unsolicited contact with others for the purpose of harassment, advertising, promoting, dating or other inappropriate conduct
Use of a fake name
Impersonation of a person or entity, or other misrepresentation of identity
Posting content that doesn't follow the Facebook Terms
(*if you do more than about 1 friend request per day!
and then this new "friend" beeing asked will complain to Facebook about it)
Touch and hold the following keys at the same time for 8-12 seconds: Power/Lock Key + The Volume Down Key.
Press the Power/Lock Key when you see the pop-up "Permanently Erase User Data & Reset Settings?". Press the Power/Lock key to confirm, or touch any Up and Down key to cancel.
When you press the Power/Lock key to confirm, another pop-up stating "Are you sure you want to continue with erase?" will show up. Press the Power/Lock key to confirm or touch any up or down key to cancel.
After pressing the Power/Lock key, your phone will be restored to factory settings.
Please remember that when you perform factory reset, then all your user applications and user data will be deleted.
Your friend requests and messages have been blocked for 30 days because you've been contacting people against their wishes. If you continue to ignore these warnings, you will permanently lose the ability to send friend requests.
Hi, If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it. Did tv showed lamp replacement requires warning/ message on screen before going to shut down? Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken. Let me know if you have additional question. Thanks.
it might be a network problem and also he might be banned from the online multiplayer for his abusive language somethimes they don't tell you youve been banned
The popup's will come when you have enter in unprotected website. Install Google chrome or Mozilla Firefox on your PC. You also remove this message by disabling your PC's firewall in control panel. This can also harms your PC unless you installed a licensed antivirus in your PC.
I have fixed this problem many times by entering just the gateway in the TCP/IP properties or all values as static e.g ip address, subnet mask and gateway as follows:-
Limited Connectivity | wireless network
Connect with an ethernet cable and find out the IP Address
Also note the Subnet Mask, Gateway, and Primary and Alternate DNS values
To get these :-
1. Double click on Local Area Connection under Control Panel --> "Network Connections" 2. Click "Support" --> Click "details"
Enter these values for the wireless area connection like this :-
1. Click "Start" -- > "Control Panel" --> "Network Connections" 2. Right click on "Wireless Area Connection" --> select "Properties" 3. Click on "TCP/IP" (in th middle box) -- > Click "Properties" 4. Click "To use the following ip address" 5. Enter the values you got from wired connection above 6. If you get any duplicate warning messages ignore these
This will resolve the issue, I have used it many times
u need to got it to your settings, then sounds and notifications, then notifications,scroll down to wireless network dector. and uncheck display message on screen and or play sound its ur choice
I have done all this Spyware is OK
I can not reinstall the OS because the program VISTA home premium SP 2 was on the computer installed from new.
