Foxconn Bluetooth 2.0 plus EDR Port_#0002.Hub_#0001
Whatever this is is under the USB Root Hub and the Intel(R) 82801G (1CH7 Family) USB Universal Host Controller-27C8 and when my new hard disk drive was put it neither it or the software for the PCI Flash Memory was put into the laptop so I am having a lot of problems with trying to get speakers hooked up to my laptop having a keyboard hooked up and printer. My internet doesnt want to come up on time or go to favorites folder-locks up-I dont know whcih problems are caused by what!!
i want driver lenovo 3000 V100 note book faxconn bluetooth plus 2.0 EDR driver & finger sensor driver plz give this both driver
Seems that your bluetooth edr is a usb device, it might be made by third company: I found this text
Your Device Info
Hardware ID
USB\VID_0A5C&PID_2101&REV_0100
Compatible IDs:
USB\CLASS_E0&SUBCLASS_01&PROT_01
USB\CLASS_E0
Version
Driver Found
Device Type
btm
Driver Version
OS Support
2K,XP,2K3,VISTA,WIN7/32bits
XP,VISTA,WIN7/64bits
Driver Date
Manufacturer
Motorola, Inc.
Foxconn Bluetooth 2 0 plus EDR Driver Download for 2K XP 2K3 VISTA WIN7...
this is zero support PC.
why mess with it at all
go to goodwill and buy a w7 up device.
end this horror now.
BTW, the show stopper here is 2 fold.
1: HP has no support on retired PCs
2: realtek the mofos., block driver downloads..
BATTERY Microsoft AC Adapter Microsoft ACPI-Compliant Control Method Battery
COMPUTER ACPI Uniprocessor PC
Diskdrive Universal HDD
DISPLAY Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC Primary IDE Channel Secondary IDE Channel Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED SMC IRCC - Fast Infrared Port
KEYBOARD Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA Audio codecs Video Codecs Midi Control devices Legacy Video Capture Devices Legacy audio drivers Microsoft Kernel System Audio Device WDM Audio Compatibility Driver Microsoft WinMM Realtek AC'97 Audio
MOUSE PS / 2 mouse
NET 1394 Adapter Remote network engine Miniport (IP) WAN Miniport (PPPOE) Parallel Direct IR Realtek RTL8139 Family PCI Fast Ethernet NIC WAN Miniport (L2TP) WAN Miniport (PPTP)
OTHER DEVICES PCI Modem
PCMCIA Generic CardBus Controller
PROCESSOR Intel Processor
SDHOST SDA Standard Compliant SD Host Controller
SYSTEM Generic Bus Button ACPI resource sixed Button tie / Untie ACPI The system CMOS / real-time clock Direct access memory controller Programmable Interrupt Controller Microcode update device Microsoft System Management BIOS Driver Software Device Enumerator Plug and Play Logical Disk Manager Manager volumes Intel (R) 82801FB/FBM SMBus Controller - 266A Intel (R) 82801FBM LPC Interface Controller - 2641 Intel (R) 82801 PCI Bridge - 2448 Microsoft ACPI-Compliant Embedded Controller Microsoft ACPI-Compliant System Microsoft Composite Battery PCI bus PCI standard host CPU bridge ISAPNP port Terminal Server Device Redirector ACPI Terminal Server Keyboard Driver Terminal Server Mouse Driver System Timer
UNKNOWN PCI FLASH memory
USB Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C Intel (R) 82801FB/FBM USB Universal Host Controller - 2658 Intel (R) 82801FB/FBM USB Universal Host Controller - 2659 Intel (R) 82801FB/FBM USB Universal Host Controller - 265A Intel (R) 82801FB/FBM USB Universal Host Controller - 265B USB Root Hub USB Root Hub USB Root Hub USB Root Hub USB Root Hub
Goto your Linux configuration utilities and configure your printer again,sometimes after a crash the drivers are reset.
Utilities differ under different flavours look and see if you can do this
Disable plug & play from BIOS. Now re-install the game and the required driver. From Control Panel--systems--Device Manager, check the properties of the Graphics card drivers and check if there is any clash of resources, if so then allot it manually. Hope this works....sodeep
hiiii ther
how r u ??
go to acer.com u will findall the vista update to ur driver
but 1st u need to check if ur machine is compatible with vista if it is
u will find all the update on the acer.com under ur laptop model
if u need any further assistance email me u take care and have fun salammmmmm {bye in arabic } p.s rate me thanks
Well, appears that your configuration can handle 4 GB of memory. I checked the Acer website for upgrades for your model, and nothing appears to jump out which could solve your problem. A few appear to be possibly helpful, but some are for XP, not Vista. Upgrading "launch manager" might be a good thing.
However, Belarc tells me that on my Acer 5630 i have listed under "Bus adapters" the following: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC And, under "other devices", i have a USB Root Hub (5x). Obviously, the two match. I go to device manager to check them out, finding them under 'univesal bus controllers", to see whether they are all working properly, and and they are. In addition, opening "system devices" reveals something called a "plug and play software device enumerator", and that checks out to be working fine as well. Check your equivalent out to see if you find a problem to fix. Hopefully you will. Let me know how things go.
nu merge bluetooth
