Something may have fallen and hit heater... disconnecting wire
And your question is?
Heard a noise, like a crash...now no hot water. Piezo wire was disconnected. I re-connected it but still won't light after following re-light instructions. Maybe something fell, or something internal faulted?
OK. So a piezoelectric starter should produce 10-20kV at the ignition tip. A 'snap' loud enough to hear. I wonder if in the 'accident' the wire between the starter button and the crystal was broken or the connector (on the tail-end of the spark unit) damaged. I presume the mechanical 'feel' of the compression button is normal but if not, you might need to replace it.
Piezo OK, pilot ignites, but after 1 min hold then release, pilot will not stay lit. Gas supply normal.
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Thermocouple. It's job is to turn off the gas supply if the pilot flame goes out. If it fails, you have the same condition as no flame. Thermocouples are inexpensive - last one I bought was about $7 so likely double that now!
