Office using its helpful
What software do you want to download?
Drivers can be downloaded from
http://www.dascom.co.uk/Support/Default.aspx?type_id=3&info_id=3&itemid=13&name=T2250&act=4
Firmware can be downloaded from
http://www.dascom.co.uk/Support/Default.aspx?type_id=7&info_id=3&itemid=13&name=T2250&act=4
SOURCE: installing T2250 tally printer
The link is :-
http://members.driverguide.com/driver/detail.php?driverid=230334
Thnks.
SOURCE: Tally T2250 Matrix Printer does not pull up paper to be printed
I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
To do this;
You should be back in action, if not post the message you see on the printers LCD display.
SOURCE: I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
SOURCE: Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
