*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Try a soft reset: *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Read all : *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345. or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Format your phone: *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Try this: *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Reset your phone: *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Try this : *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Reset your sofwares : *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3) or try this(But it will fully format your phone) Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
dial the phone (use a cell for test run/practice) ...once you hear the
message press "*" (the asterisk key) and enter your 4 digit code (the
default code is 1234 or sometimes 0000) you really should change this,
this might have been done in the initial setup... read your manual for
the exact commands to be use after/during retrieving msg....
