My acer 3680 laptop will not power up with or with out battery/plugged ito power. Used 1 day and would not turn on the next, laptop has not even done 20 hours work over a period of time. very disapointed with this product
Here is website, try that. hope that helps
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-LAP0239(Other+Products).aspx?dsNavigation=Ns%7eproduct+Type%7c101%7c1%7c%2cN%7e27-4294953664-4294951616&Title=Acer+ASPIRE+3680+replacement++battery
try doing power drain by disconnecting all the cables and battery then press and hold down the power button for 1 min then , check for working if not , you need to service the system
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Hi i think the problem is with the battery or power supply.When you power up the laptop without the external keyboard and mouse everything is ok, yes?Check that the battery is charging properly and that the charger is doing its job.
there are some reasons laptop can't power on, try to troubleshoot.
1. Make sure that your ac adapter is working. if you plug battery and ac adapter, the battery chargin led will be orange and if the battery is full, the led will be yellow.
2. Can you power on using battery ? if you can and you can't power on using ac adapter (i assume your ac adapter is working). the problem will be your power port.
if you can't power on using battery and your battery is working ok. the problem will be motherboard.
