Honeywell HY-048BP Tower Fan Logo
The remote is broke and i need to get another one how would i do that
The remote is broke and i neet to order another remote but cant find one where do i need to go
Hi .having a problem with the remote. have Press a wrong switch and getting the Image purple . Please help Remote rm 88E
Hello Neeting, it would be good if you commented on the brand and model of the device that shows you the image of Purple
to be able to find a more successful solution
I wait your answer
Greetings Franco Dosil
Hola Neeting, seria bueno de que comentes marca y modelo del aparato que te muestra la imagen Purpura
para poder encontrar una solucion mas acertada
Espero tu respuesta
Saludos Franco Dosil
How to reset one for all remotecontrol...eu-ur 1669 as well do I neet to keep the tv on or off.thenks
To reset it, take out the battery from its battery compartment. The remote will reset itself, when you re-insert the battery.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Remote contol code for bunkerhill security dvr
My remove also broke after I dropped it
2helpful
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
I broke my daenyx remote and i cant turn my t.v on and i cant find a universal remote that will work or any codes
The Harmony 600 will work with a Daenyx tv. It costs about $80.00 and codes are provided by the Harmony website during programming. The site just needs the product name and model number.
1helpful
Need remote codes
Get the 8.00 rca universal remote at wal mart (model rcr312w) follow the auto scan instructions and it will work.  I just had this same problem, bought 4 universal remotes and this one worked!
Neet battery cover for Philips TSU600 Pronto remote control
Battery Covers sell worldwide at Rogers for around $3-$10. Also, cheaper 50c ones are sold on EBay, Kijiji, and Craigslist.
2answers
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
3answers
Ilo tv.
my dog ate my remote and broke it and i just called an ordered a new remote from the # walmart extended service plan gave me the # is 800-216-5156 they need the model # and or serial # and the remote only cost me 14.99 plus shipping hope that helps!!!
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
