I just purchased an inexpensive Honeywell fan model ht-900-wm at Walmart. It said there was a user's manual in the box, but there is none. It is a turbo type table top fan in a black plastic housing. I can not see how to open the housing to clean the blades and motor of accumulated dust. Thanks.
First remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
My Honeywell HT-900 opens a little differently. There are six screws (all visible) evenly spaced around the back of the fan body. To open, loosen these screws with a Phillips head screwdriver. Don't actually take them out, just loosen them completely. Then the front face of the fan should slide off without much effort.
