Bought today clock works but nothing else please help
Test the power outlet plug some lamp desk if work is o.k if NOT reset the c. breaker. follow this stepFirst check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
SOURCE: reset my clock
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you should call the dealer or store where you got the oven to see if they have a contact number for Swan.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Keys to microwave do not work, it keeps beeping though.
It sounds as though the pc board behind the keys is faulty.
SOURCE: whirlpool gh5184xps over-the-counter microwave no power
There is a high voltage fuse in the unit attatched to the high voltage capacitor, it is the most common problem for microwaves not working. Also check the protective diode,the high voltage capacitor as well as the transformer if the fuse is ok. Good Luck.
