Computers & Internet Logo
Posted on Mar 06, 2009
Fiendster layouts and codes - Computers & Internet
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
484
Points
Hi add nlang pow me ahh ank ng pinoy pow
Anonymous
Level 1:
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
484
Points
Pano kaya gwin to??haixt!!
Forgot 4digit code
Code for what? Really need more information to help.
tip
How To Install MySpace LayOut(s) 2.0
Hello:
This is a Tutorial on How to Install a MySpace LayOut 2.0.
First you will need to log into your MySpace Account, and then from there Look at the Tutorial(s) below:
STEP 1:
Goto Customize Profile, this window below will appear. Then Click on "Appearance"... :)
STEP 2:
Click on "Select ~ Theme"
STEP 3:
Click on "No ~ Theme"
STEP 4/5:
You may have a Previous LayOut Currently Installed, or you may not yet have UpGraded to the 2.0 Profile LayOut(s). If you have Upgraded, or have a Current MySpace 2.0 LayOut Installed, and want to Install a New MySpace 2.0 LayOut: Then Click on "Remove"
STEP 5:
Click ~ on "CSS"
STEP 6:
Click In the "Text ~ Editor Box"
STEP 7:
Right ~ Click, and then Click "Paste"
STEP 8:
The New LayOut Code is In the Box, thereafter, Click "Publish"
STEP 9:
Click on your "Profile"
STEP 10:
Your New MySpace LayOut 2.0 is now Installed. Enjoy!
on Apr 02, 2010 • Computers & Internet
Looking for the cylinder layout for a 2006 Mazda 6, 3.0 liter V6 engine, also the engine code is an S
1,2,3 are across the back under the intake and4,5,6 are across the front
I deleted my mainscreen layout on my MotoQ9c how do i get it back
Call Sprint and reset the phone. They will give you a code to type into the keypad along with another code to activate the reset.
My layout is all over the place
Some layouts dont have the updated codes. You need to check and see if you are using the new or the old myspace. Type in which ever layout you want to you use in Google and always put it in your about me :) hope this helped. good luck.
Your Problem: hi, have a error code 45 ,automatic trans axle malfunctioning,I just pay $1000 for transmission fix, the guy said that code has nothing to do w/ transmission work. tx. jairo.
A transaxle, in the automotive field, is a major mechanical component which combines the functionality of the transmission, the differential and associated components of the driven axle into one integrated assembly. Transaxles are near universal in all automobile configurations that have the engine placed at the same end of the car as the driven wheels: the front-engine, front-wheel drive layout, rear-engine, rear-wheel drive layout and rear mid-engine, rear-wheel drive layout arrangements.
All i want is a stinking layout im trying to figure out how can i put a layout in my friendster...i started doing this like 6months ago and still no layout
This is the instruction on how to place the code above into your frienster.
1. Log into friendster
2. Click on profile
3. Click on edit profile
4. Click on customize
5. Then go scroll down he page to Advanced Customization(customize css)
6. In the box below the Advanced Customization(customize css)
7. Paste the copied code for your background into the box.
8. Then save
9. Then click on (view your profile now) to see your new background.
You can find background codes at http://www.informationzoo.com/Friendster.html
5helpful
3answers
Deleted home screen layout
going in setting click more option then select reset and type reset code 0000 your mobile reset succesfuly but you loosed your data
1helpful
How to help editing existing myspace profile
Ok No problem, I am here to help. If you want to add a new myspace layout what you have to do is type in google, ""myspace layouts"". Its going to give you many site where you can get different layouts for myspace. After you have found the one you like, there should be a code that they give you. Copy the code now. Next make sure you are login into your account and go to where it says "" Edit Profile"". Paste the code that you copied earlier in the "" About Me Section"". When you have done that, click ""Save All changes"". And You are done! To see your new profile click in ""My URL: "". Hope it Works!
Grand Canyon Tech
Grand Canyon Tech
