If the flame on your Speed Queen commercial dryer model STD32DG goes out 10 seconds after start-up and does not come back on, it could be due to a few different reasons. Here are some things you can check to troubleshoot the issue:
- Check for obstructions: Make sure the dryer's exhaust vent is not blocked by lint or other debris. This can cause the dryer to overheat and shut off the flame prematurely.
- Check the gas supply: Make sure the gas supply to the dryer is turned on and the gas valves are not clogged. You may need to call a professional to check the gas lines and valves for any issues.
- Check the igniter: The igniter is responsible for lighting the flame. If it's not functioning properly, it can prevent the flame from staying lit. You can check the igniter with a multimeter to make sure it's getting the proper voltage.
- Check the flame sensor: The flame sensor detects the heat from the flame and tells the control board to keep the gas valve open. If the sensor is dirty or defective, it can cause the flame to shut off prematurely. You can clean the sensor with a soft cloth or replace it if it's defective.
- Call a professional: If none of the above steps work, it's best to call a professional repair service to diagnose and fix the issue. They can safely and effectively troubleshoot the issue and get your dryer running again.
Remember to always prioritize your safety when attempting to troubleshoot any issues with your appliances. If you're unsure about how to proceed, it's best to seek professional help to avoid causing any further damage or risking your safety.
