Hi!
I have a problem with my H/K AVR 5000 build in 2001: It suddenly switches back into standby without any reason. This usually happens approx 2 min after I have switched it on, but could be also after a few hours. After this it fails to get switched on again and immediately jumps back into standby.
There is a good chance that it works again the next day, but this is not for sure. This behaviour is independent from the source or volume (I believe). I already un- and replugged all wires including those of the loudspeakers. Even a reset of the amp did not help.
My first guess was that the protection curcuit is being triggered, however the standby LEDs remains orange and does no turn red as it should be in this case according to the manual.
Perhaps it is worth to mention that on very rare occasions the amp turns up the volume by itself at least I did not press any button on the remote control. This started a few years ago, but I could live with that.
Any ideas or experience with other AVR models?
Many thanks in advance,
Manfred
SOURCE: long startup
Problem is a bad relay. Temporary solution is to clean the contacts. Permanent solution is replacement.
SOURCE: standby power switch
If you are concerned about humidity and switches, spray them with DeOxit. You can get it at Radio Shack.
SOURCE: Teac A-H300 Amplifier
It may be your unit is going into protect mode because of a problem in the power amp stage of your amp. If so, then it is time to see a repair shop. Good luck.
SOURCE: TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
SOURCE: Protect Mode With Sony str-de595
Hi snark63
Ypou have an intermittent problem that sounds to be heat related... the more work the amp does, the more heat generated by the output stages. This will be aggravating some poor solder joints that are cracked or dry. The unit needs some repair work done in these areas. If you have good experience with a soldering iron, the cure for this is to resolder the power stages of the unit, or any other solder joints that look to be failing.
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
