Step by step would be great
1.Turn on the printer. Open the cover to expose the printer carriage. Wait for 3 seconds and unplug the printer from the electrical outlet. The print cartridge will stay in place by unplugging the power.
2.Remove the ink cartridge from the carriage by lifting up on the tab holding each cartridge in place. Remove the ink cartridge by pulling it out and up.
3.Use a lint-free cloth to gently wipe the copper contacts on the bottom of the ink cartridges. If the residue is stubborn and won't wipe off, use a cotton swab dipped in bottled water to remove the residue by rubbing gently. Do not wipe the nozzle on the ink cartridge; wipe only the flat contacts. Lay the cleaned ink cartridge on it side on newspaper. Do not stand it upright with the copper contacts touching the newspaper or the ink will drain out.
4.Use the lint-free cloth to wipe the contact points in the print carriage. If the residue won't come off, use a cotton swab wet with bottled water to remove the residue. Wait 5 minutes after you have cleaned the printer contacts before replacing the ink cartridge.
5.Place the ink cartridges back in the printer cartridge. Snap down the top to secure the cartridges. Plug the power cord in the wall outlet. Close the cover. The printer is ready to use after running through the initialization.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: How do I remove a Canon 730 Multipass print head
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
SOURCE: print head cleaning
The print head is the black plastic bracket at the back and bottom of the unit that holds the ink cartridges - it looks like one piece but its actually two. Remove the four ink cartridges and the just pull the back of the black plastic unit forward and lift out. There are no clips and it comes out effortlessly.
