Hi, I have just acquired a Nokia N85 phone. I have a Mitsubishi Ttriton which comes with a standard car Kit. When I search for Bluetooth devices the phine locates the car kit (Parrot VM3.18) however I am unable to pair it with the device,
Just took my vehicle into Mitsubishi and they haev advised that the phone may be a little to advaced for this car kit.
As the car is only 2 years old does anyone have any ideas as to what I can do to pair the N85 to my Parrot VM3.18. Thank you
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
For all G3 phone try: Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
My nokia n85 wouldnt pair up with my parrot ck3000 hands free kit i managed to get it working by only turning on the cars ignition once my phone had started to try pairing and to my surprize it works now no more please pair device everytime i get in my car
I had the same problem with my N85 not connecting to my Parrott CK 3000. I read elsewhere that others had the same problem with their N96 and they just carried on trying again and again to pair it until it worked. I tried this and after around 10 attempts in a row it paired. Now it works.
Just persist and it should work.
It should pair no problems, the pairing code is 1234, however you will not be able to sync your contacts, you have to do this manually.
Go into contacts, Mark All, send via bluetooth, select your carkit and send.
Gadget
The object push listed above should work. Or do what I did.
Try sending an MP3 to the Parrot kit. I couldn't even
get the Parrot BT in my car to ask for the BT password numbers but found
out to
try sending an MP3, which will fail by the way, and it asked for the
password finally.
There was an
error in my case, but then the phone asked to connect to the Parrot
again and the pairing worked.
There is an issue with newer Nokia
phones, something I will be thinking about next phone upgrade.
Hi. I had the same problem with Nokia 5800. After about 200 tries it works. I did nothing special the time I got it but it would seem that if you keep trying it will work. Very starange if you ask me.
Unfortunatley I cannot get the prompt to come up which asks to enter the pairing code. My old Nokia phone pairs fine with this same code. It just appears to be the N85
I just purchased a nokia 5800 and it will not pair to my Parrot VM3.28 fitted to my 2007 Triton. Again any suggestions?
Same phone, same problems.
I have a parrot CK3000 evo, My N95 paired up with no problems - worked great for months.
Now that I have a N85 It just wont pair.
It will find the Parrot kit no problem, but when you ask it to pair, it just says "pairing failed" And the Parrot kit says "please pair your device" or something equally annoying.
Is there a software update for the parrot?
I have a Peugeot 308. The N85 pairs with the cars Bluetooth but wont transfer calls either to or from the vehicle
Nokia 5800 will not pair with CK3100 Parrott.
I have the same with my N85 and Parrot. tried tens of times and nothing. Still can hear "pair your devices", "pair your devices". N95 worked perfectly :-( Why I replaced the phone? Stupid me!
cant connect nokia 5800 to parrot ck3000 evolution
Guess what, I have the same problem.... I will try 10 times and see if it connects..... how annoying
Hi have tried pairing my Nokia lumina 625 iam asked for code I put it in and it tells me it's full how do I reset
