Question about Parrot 3000 Evolution Advanced Bluetooth Microphone Car Kit
How can i reset my parrot 3100 to factory settings so as i can get it to pair with my samsung m8800, now that i have changed car and phone?
Starnley Johnwells
  • 1,031 Answers
Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset tHIS back to factory settings
Posted on Aug 26, 2009
Testimonial: "have tried this and was correct, thanks."
None of our iphones can detect the parrot 3100
https://discussions.apple.com/thread/4349029?start=495&tstart=0
the above thread has several suggestions for solutions. The most common that seems to work is a phone reset. Make sure you backup any data first though.
Nov 12, 2016 | Parrot Ck3100 Lcd Voice Bluetooth Ck-3100...
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Hi I cannot pair my new phone by bluetooth My new
try deleting some of the paried devices from the settings menu to make room for a new phone.
Dec 27, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Unable to use phone book contacts between Nokia 5800 and Parrot 3100
You need to check that both the 3100 and the 5800 are using the latest software. There were problems with the older software but they have been resolved.
On the 5800: Settings>Phone>Phone mgmt.>Device updates>Options>Check for updates (Assumes your 5800 has a working internet connection). Othewise use software updates from Nokia PCsuite.
For the 3100: Download the software update tool from www.parrot.com to a bluetooth enabled notebook. Run the update tool and just follow the instructions. If you don't have wireless internet on your notebook, run the update tool first while connected to the net to download the update files before taking the notebook into the car. The 3100 must be in software update mode before you connect the notebook via bluetooth. Settings>Advanced settings>Software Update>Activate.
I found that it took a couple of attempts to get the connection to work, but once it was made the update completed fine. The 3100 then resets itself and you need to pair the 5800 again. Once it's paired, the contacts will synchronise.
I did this about 30 minutes ago, so I know it works.
Good luck
Nov 08, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Hands free Parrot will not hold any details in its memory
Use parrot sw update with a computer. Connect your computer to parrot via bluetooth and complete update. Delete all old paired devices too.
Mar 05, 2009 | Parrot Par Ck3000 Evolution Ck3000...
My kit will not allow me to pair a phone, it comes up memory full i have unpaired all phones, how do i clear the memory (Parrot 3100 to Samsung tocco)
Disconnecting your car battery would clear the memory but ideally you need to update the firmware of your car kit through a bluetooth connection, instructions and software to do this can be found at http://www.parrot.com/uk/support/downloads. You need the Parrot software update tool. Instructions to do this are at http://www.parrot.com/uk/support/downloads/texte_fck_2/image/ck3x00_update_procedure__en.pdf for XP or http://www.parrot.com/documents/en/support/parrotck3100-vistaupgradeprocedureeng.pdf for Vista. Hope this helps if you haven't figured this out for yourself already.
Jan 07, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Parrot 3100 LCD Phone book problem
go into phone book, select mark all then send as a business card to parrot.
Jun 15, 2008 | Parrot Hands-Free Car Kit with LCD Display...
Parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Apr 19, 2008 | Lands Phones
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot ck 3100 - Memory Full
Try reseting it to the Factory default. it should solve the problem.
Dec 05, 2007 | Nokia N95 Cellular Phone
Parrot 3000 Evolution Advanced Bluetooth Microphone Car Kit Logo
23,040 people viewed this question
Top Parrot Cell Phones Experts
Marvin
Marvin
ray gallant
john h
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
