Adobe Acrobat 6.0 Professional for PC Logo
Posted on Mar 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wanting to be able to save what is typed in the form fields I mak
I have a word doc. that made into a pdf. with the 6.0 Professional and the form fields for like: Name address email, etc. I want the person who is filling the pdf form out to be able to save it so they can email it back to me. But I can not seem to find in the help section to show how to keep it from deleting when you go to save or print or to email the form back.
Anonymous
Level 3:
Master:
  • Master 404 Answers
  • Posted on Mar 03, 2009
Anonymous
Master
Level 3:
Master:
Answers
404
Questions
Helped
125521
Points
1031
Pdf is made not to be modified unless they have a pdf professional themselves. i recommend to use a web based application form.
1helpful
Easy one for you i guess , but i have just designed a sales page in word but i dont know how to save it so it can be uploaded to my host ? what should i save it as and what type of file ??
if you are using microsoft office 2007 then by default it save as docx form..... I suggest you to save this file into the doc 2003 which have a utility in ofice..to convert in doc 2003 format...(because most of the user still using office 2003)
Just go to file option menu and there is option for save as click and save this doc.....(if you find a solution plz rated us)
Hope it will wrk for you
tip
Edit PDF File in Microsoft Word 2013
Microsoft Office includes a new feature named PDF reflow which allows users to open PDF files in Word 2013 and do editing according to the requirement and you can save that file either as Word doc or PDF again. Through simple guide below you may know how to edit PDF in Word .
Step one
Open Word and then to open your PDF file from computer desktop navigate through menu File Open Computer Desktop
Step two
Word will take few minutes to convert PDF into Word Doc file so be patient and let it complete the process. When your file will get open click Enable Editing button
Now, you are enabled to do editing in your document just as you do in a normal Word file
Step three
When you finish editing save your file and navigate through File tab Save As and choose PDF format from the list of options followed by Save as type: or you can set it to Word Doc, it depends on your choice and then click Save button
Predecessors of Microsoft Word has embedded feature to save Word Doc as PDF file but it includes the ability to convert PDF into Word doc and then again save it to PDF, which is quite useful option.
I want to add two value of two field and display another field in form of ms access 2003
set field number 3 = to sum of first 2
example
A1 = 5
B1 = 6
C1 = A1+B1 which will make C1 show 11
type in C1 = then move cursor (arrow key) over to A1 then type + then move cursor to B1 then hit enter - formula showing in C1 on top should show
=A1+B1 and valud in cell should show 11
Microsoft Access
You need to set up security and different profiles for different people. that is the safest way. But an easier way is to have you enter data in one form and them enter their data in another form. In their form edit the properties of the fields that you want left alone. You need to set the properties to locked in the form where they do their data entry but leave them unlocked where you do your data entry. Just creat a second form by saving the first one under a different name. Also you might want to remove the fields from the tab stop list.
2helpful
2answers
Access to PDF files on email attachments
Try checking the file association. Open the Control Panel, Click on Folder Options, Select the File Types tab, Scroll down to locate the PDF extension, Select the PDF extension, Look below in the Details for PDF extension and select Change, locate and select Adobe Acrobat or Adobe Reader, then make sure there is a check mark in the "Always use the selected program to open this kind of file", Click on OK and then close.
2answers
Microsoft word not responds
TRY SAVING IN ALL FORMS OF WORD
LIKE 97- PRESENT
5answers
I need help converting a word document into a fillable form.
You can make use of several softwares like Solid Converter PDF, Adobe Acrobat, Scansoft etc to convert a word document into a fillable form. If you are looking at any specific application please let us know.
Printing a 2007 Word document on Word 2000 and yes I've tried the Converter but to no use.
Open the document in word 2007, click file, save as and in the save as dialog box at the very bottom is a field "save as type" Click the down arrow and scroll down to and select Word 6.0/95(*.doc)
In the File Name: field type a new name so that you don't save over your original.
Click save.
The new file will open in word 2000.
Relation
populate the field's controlsource with =forms.formname.field and then from the properties of the new field change the format to a required one, on saving it will use that format.
18helpful
3answers
Using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
