i have an att phone but it broke so i tried to put the sims card in a t mobile sgh-t429i have an att phone but it broke so i tried to put the sims card in a t mobile sgh-t429
You can't post conmments that contain an email address.
hi to get codes visit onlinegsmunlock.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock your mobile.
You can use codes to unlock your Samsung SGH-T429! Unlocking using codes is easy and the safest method!!You can get the codes from your service provider or from reliable online sites like mobileunlocksolutions.com .By specifying Your phone's manufacture, model,country and network, you'll be able to get the codes!The steps to unlock is simple here and the codes are reasonably priced!!!! http://forum2.mobile-review.com/showthread.php?41863-Unlock-V3x
Hi you can use codes to unlock the mobile .to get the unlock codes visit here wickedunlock Here they ask the following details before rendering the unlock codes they are 1. Mobile model 2. Country from where you brought the mobile 3. Provider to which the mobile is locked 4. Imei number of the mobile Finally they will send you the unlock codes .once you entered the code in your mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim.
You can unlock your mobile yourself at home to unlock your Samsung model mobile using codes are the best way , why i am saying codes means to unlock your mobile with codes are simple & easy way, Get the unlock code from this site www.prounlocking.com/samsung/rs8wp8 ,it has the best instructions and simple ways to unlock your mobile from the network lock............If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
The sim wont work because it is locked to the att network which means it will only work with att sim cards.
You will have to unlock the phone from the att network before it can work with the T mobile sim card
You should contact your network provider so as to get steps to unlocking your phone from the att network or you should contact a repairer to help you unlock it
WHEN I USED THIS CODE ON MINE AFTER ENTERING THE 1ST SET OF NUMBERS THE
SCREEN WENT BACK TO WRONG CARD BUT I CONTINUED ENTERING THE SECOND SET
OF NUMBERS NOTHING HAPPENED SO I POWERED OFF AND THEN ON THE PHONE AND
IT WORKED FOR ME IM USING A ATT SIM CARD IN IT NOW GOOD LUCK
I also have a x426 from 2003 and it wont work with the new ATT sim cards either, This is because of the Cingular/ATT merger which created a new network. The older original ATT phone must be unlocked to use a sim card from the new merged network. Try calling ATT Mobility customer service and request the subsidy unlock code. They are required to give it to you upon request, but it takes several days usually to get the code. I know because I used to work at a ATT call center.
