Philips GoGear SA3125/37 MP3 Player Logo
Posted on Feb 28, 2009
Y wont the razor phone charger charge my MP3 - Philips GoGear SA3125/37 MP3 Player
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
415
Points
9
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
I try to charge my razor using my blackberry charger but it wont work it keeps saying "unable to charge" why?
hello,
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
thank you and thanks for using fixya.
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
1helpful
2answers
Wnat to know if emerson player model 414-4 has a charger
it will charge on a cell charger too. you can use the chrger to the safelink phone, a razor phone, and some boost mobile chargers
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
2helpful
Motorola Razor V3 wont charge
Your Charger Port On Your Phone May Be Loose or Begining To Have A Break in The Wire, Seek A Phone Technician If You Do Not Have An Advanced Understanding Of Phone Circutry
Razor phone won't charge
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
SanDisk Sansa m250 MP3 player
hey :
sir you damaged your battery by charging it with the razor charger.
the razor charger have more volts than your device sw the only solution you got is replacing your devise's battery .
click here to purchase one
WON'T CHARGE OR POWER ON
Your going to need to wall outlet, when the player is completely discharged it is impossible to charge via the usb.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
