Replace your graphics card or update the drivers to it...
well unfortunately once you replace all of the hardware you are kinda out of options..cause it is a hardware problem...sorry couldn't help you more. good luck
Found a new dianostic tool for DirectX you may be interested in. Click start>run>type msinfo32.exe (or start>accessories>system tools>system information)>this will bring up the system information screen. Click on Tools and DirectX Diagnostic Tool. Lots of tabs and troubleshooting areas for you.
Good luck, let me know how it turns out.
Part Number:
Aspire5535 Aspire 5535
Feature
Description
Part Number
Varies by specifications
Processor / Speed
AMD
Turion™ X2 Ultra dual-core mobile technology
ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50
GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology,
or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1
MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD
HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor
QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W),
supporting AMD HyperTransport™ 3.0 technology.
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules.
Video Subsystem
ATI
Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of
dedicated system memory, up to 1792 MB of shared system memory),
supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR)
technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6"
HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer
CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via
Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
120/160/250/320 GB or larger hard disk drive.
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
PCCard Support
1 ExpressCard™/54 slot.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model)
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model)
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapt
i have already tried that actually
Make sure XP is installed and just the drivers for your hardware. Then try running just one game and see what happens.
