Compaq Armada M700 Notebook Logo
Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove deep freeze
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i am not able to access controls/setting and c: drive. the task manager shows the file DF5serv.exe running. i couldnot access deep freeze control using ctrl,alt, shift,f6 and there is no icon on task bar. how do i remove this program from my system. help is greatly appreciated.
thanks
  • ahmedcorel Mar 12, 2009
    i've been using deep freeze standard 6.3 for approximatly 1,5 years on windows vista, i haven't faced any problem with it, but after all this time, i decided to update my windows, it has been updated perfectly and i installed a couple of programs after that, but when i restarted my windows (without freezing the system), i found that my windows system has been frozen and the tray icon is disappeared, i tried everything to get to the deepfreeze window and get it thaw but i couldn't, i even pressed alt,ctl,shift,f6, but no use.
    the buttom line, there is no deepfreeze tray icon, and i'm frozen forever.
    i guess that i'm going to have to format....
Anonymous
Level 2:
Sergeant:
  • Expert 319 Answers
  • Posted on Feb 27, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
319
Questions
Helped
173748
Points
932
Try deleting it manually, go into safemode with cmd prompt only.
del c:\[filedir][filename]
it will induce an error next time it runs, but you can regedit.exe your way out of that one
  • frank edwards
    frank edwards Jan 07, 2014
    I need a Deep freeze activation code try to activate online couldn't and offline demands for activation code can any one help out thanks
  • frank edwards
1helpful
2answers
Cannot uninstall deep freeze
uninstall it using administrator password
tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 • Computers & Internet
12helpful
4answers
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
3helpful
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Deep Freeze is uninstalled and your computer is rebooted.
I have window s 7 on my pc & I have deep freeze 7 installed on it and i deep frozen my drive c,but after some virus problem my all drive have been deep freezed and now the deep freeze program not...
To uninstall:
Please comment if the information has been helpful. Thank you and regards.
1helpful
Remove deep freeze from computer
To uninstall:
Please post your feedback and Vote if the problem resolved as per your satisfaction.
1helpful
How to uninstall deep freeze from my pc
(Please let us know if you find the following has been useful.)
In order to uninstall it, you need to disable Deep Freeze first. To do that, please follow the steps below:
To uninstall:
I hope this solves your issue. Regards.
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
346helpful
25answers
How to uninstall deep freeze from your pc?
To uninstall:
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
