Not working on ac and dc voltage
SOURCE: WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
SOURCE: I looking for fluke 179 service manual
Go take a look here please: http://www.fluke.com/fluke/usen/support/default.htm I found your manual here: http://www.fluke.com/Fluke/usen/support/manuals/default.htme: but you may not be able to go to this directly. Click on the Manuals tab then search your model number.
I trust this is what you are looking for.
Thanks for your interest in FixYa.com
SOURCE: fluke 179 has ---- on the display when ohms or
Switch is the problem here, see if you can clean contacts or check if switch contacts are broken.
SOURCE: My Fluke 179 has stopped beeping (mode
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem.
