Can't get my mouse to work but it worked in system recovery upon start up when u press f8 someone help pls
SOURCE: Don't know how to reformat my emachine T5010 desktop PC
Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort.
Some Computer Manufacturers Make Reformatting EasyMany name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed.
Back Up Your Files Before You Reformat Your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
SOURCE: Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
SOURCE: I LOST MY RECOVERY DISK CAN I STILL RESET MY EMACHINE DESKTOP?
You need to go the website for your product and down load the driver. I recommend that when ever you charge are reinstall you OS that you download your drivers first Burn them onto a CD that way you can install them anytime you need them. This link should take you the website that you need.
http://www.emachines.com/
don't know your product this will get you to there site from there go to drivers and download drivers and recovery software.
SOURCE: Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines
T5082 Computer, the eMachines eMachines T5082 Computer takes the
PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and
comes installed with 512 MB (removable) of Memory. You can upgrade your
eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory,
the system has 2 sockets to install Memory, already with 512 MB
(removable) standard Memory installed. For best Computer performance
use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
SOURCE: My emachine loads up PCI device listing and cant exit.
First of all your recovery disk didn't work and so it keep asking you for it.
Here’s what to do. Boot from your windows disc and choose Recovery Console when the Welcome to Setup screen appears (Press R to Repair the installation using the Recovery Console.) (Not the repair option on the installation/setup options screen).
If you do not have a standard US keyboard setup, e.g. You are in the UK with a UK setup, watch the grey strip at the bottom of the screen when the recovery console begins to load, which will ask you to press F5 (I think) and choose your keyboard language. If you don’t do this, your admin password, particularly if it contains non-alphanumerical characters may not be recognised. You will be taken to a black screen, which will ask which operating you wish to log in to. If you only have one, press ‘1’ and enter. If you have more than one, choose the operating system you wish log into and type in the appropriate number, followed by enter.
You will then be asked for the administrator password. If you do not have one press enter. If you do type it in and press enter.
You will be taken to a command prompt. Type in ‘chkdsk /r’ without the quotes. Note there is a space between the K and the forward slash. If you get the error message ‘Autochk.exe cannot be found’ or some other error in relation to a missing ‘autochk.exe’ file, then do the following at command prompt:
Type:CD C:\WINDOWS\SYSTEM32
Now try the ‘CHKDSK /r’ command again.
This may take quite some time. It will check the disk and file system for errors and try to repair them.
You will get a report at the end telling you if errors were found and if they were fixed-.
Sometimes you get a message saying the chkdsk could not run because the disc contains unrecoverable errors or something similar.
The next step is to reboot. If chkdsk ran and corrected your errors, you may well be able to boot back into your o/s.
If chkdsk was not successful and you still cannot boot or could not run chkdsk the next step is the same.
Follow the instructions above and go back into recovery console.
This time at the command prompt type ‘fixboot’, again without the quotes and enter.
You may get a message along the lines of are you sure; this may make your data unrecoverable. You have to make that decision. I personally have never known this happen, and my philosophical view is my data is currently unreadable (note: not unrecoverable) and I am prepared to take the chance. Are you?
Then you have two choices. Reboot to see if this works. If it does, all well and good. If not, or if you choose not to reboot (not critical, but not recommended), at the command prompt in recovery console type ‘fixmbr’, again without the quotes. You may get a similar warning to the ‘fixboot’ command. My advice is the same, but you much choose whether to take the risk or not. Restart.
Hopefully you will now have access to your pc and files.
These are the steps I take when encountering this and similar problems. I have found them to be 99.9% effective- in other words, they only failed me once and in that situation I believe the hard drive to have been defective and replaced it.
Without warranty, at your own risk.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
or
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management."
Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password.
Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
hope this helps
