Backfiring,Wont Idle,Missing on acceleration,Just running awful then smooth out then back to the same thing,But always popping through the exhaust when I let the throttle up.
SOURCE: My 1996 Kawasaki Vulvan 800 backfires and stalls on acceleration?
sounds as if you may have a little trash or gunk in your fuel lines. remove the tank and lightly blow air form a waterless air line through the hose that feeds the carbs, this will dislodge and remove any trash that may have settled in the line and jets.( be sure the air box is closed or coverd so you do not blow fuel in your face)
SOURCE: 2005 VSTAR 1100 Silverado Backfire
Are you running on original pipes or have you installed aftermarket pipes that are louder ?? I had the same problem with aftermarket pipes and come to find out my carbs were not jetted the way they were supposed to have been done when I installed the pipes.Also there are two chrome tubes starting at the front of the engine going under the seat towards the rear--- there is a rubber hose connection connecting each side .You should disconnect these hoses and bypass the tubes-- in other words use one hose to connect the front two tubes together and the other to connect the rear tubes together , its some sort of early emmission thing that will cause some backfire
SOURCE: 02 DYNA WIDE GLIDE WON'T IDLE UNLESS CHOKE IS OUT.
Sounds like you've got a vacuum leak somewhere. Either your intake seals or the carb seal is leaking air. Have you replaced the air filter housing? On the Evolution and later engines, the carb is designed as a "spigot seal" type carb. In other words, it just pushes into a seal instead of bolting on like the older carbs did. This means that the carb has to be aligned correctly or an air leak can occur around the seal. The air filter assembly is what holds the carb. into the seal and aligns the carb.
If you haven't messed with the air filter assembly there is one other thing that I've seen cause this problem. Your bike has two vacuum operated devices on it. One is the VOES switch and the other is the fuel petcock. The VOES switch is part of th igniton system and the petcock is the fuel valve on the fuel tank. The vacuum comes from either the carb or the intake manifold and is routed to the devices by a vacuum hose. Make sure this hose in connected to all three locations and has no holes in it. The vacuum hose to the petcock is on the backside of the petcock and the VOES is located on the bottom of the frame top tube under the fuel tank near the carb.
I have seen the vacuum operated petcock cause a vacuum leak in at least one occasion. Normally, when they go bad they just shut the fuel off to the carb and the engine won't run. But, I did have one that caused a severe vacuum leak and the bike acted exactly like you're describing. I took the petcock out of the tank. Drain the fuel first, not easy to do with the petcock being vacuum operated. I got a large funnel and held it under the petcock while I slowly unscrewed it. Once you have the petcock out, you'll see four small screws on the back side of it where the vacuum hose connects. Remove the screws and check the diagraphm behind the plate. Be careful, there is a small spring behind the plate. Take the petcock apart carefully so you can remember how to properly reassemble it.
Personally, I would eliminate the vacuum operated petcock and replace it with a high quality manual operated petcock. Like I said earlier, if they malfunction they usually shut the fuel off to the engine. There you are, a full tank of fuel but none to the engine. I'd replace it with an original Harley unit for a 1995 or earlier bike or a high quality aftermarket unit like a Pingle.
You need to find this problem before you ride the bike too much. The lean mixture resulting from a vacuum leak will cause the engine to run very hot.
SOURCE: Vstar 1100 idling rough and backfiring letting off the throttle
It sounds to me that your carbs might be a little gunked up - you mentioned the gas may have been old, so it's possible that the smaller (idle) jets are slightly plugged up. Fresh fuel might do the trick and/or you could try using a fuel system cleaner and water remover. This problem might 'solve itself' with a little time.
As far as the backfire - this might be either from the carb issue or it could be related to that rattle you mentioned - you could have a loose connection at or near the head - this can **** air and cause a backfire.
I hope this helped!
SOURCE: 2001 harley fatboy caugh and pops back through
If you try to ride the bike or rev the engine up while it's cold, this is normal. Most engines will do this because the mixture is lean for a cold engine. When you start the engine, allow the engine to warm until it goes into the slower idle speed.
Good Luck
Steve
