Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
SOURCE: acer travelmate 292elcI problem starting
Hi, sorry to hear you are having problems. When this happens it usually suggests that the CPU/system board has failed. If the laptop is still under warranty I would suggest taking it back because this is something that will be covered and they should be able to fix it or replace the laptop itself. If not you may have to pay to have the system board/CPU replaced. Good luck and hope this helps. Si :)
SOURCE: Blank screen
Quite possible that the machine is defaulting to external display only. Check your BIOS for this and try any function keys/switches that are available.
SOURCE: my everex 1502 wont power up just beeps and goes
this commonly occour when there are any complaints with the RAM module. try replacing them or unplug it and again reinsert it som times this can also be caused due o loose contact
SOURCE: HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
SOURCE: blk screen when trying to start up after pulling
Hook up just the AC Adapter to the laptop with the battery out and see if the video comes back by turning on the laptop.
If it doesn't then take out the memory and reseat each memory stick one at a time in each slot one at a time.
Try turning on the laptop after each stick reinsertion and see if you get video back.
If you don't then the last two things to try would be to take out the hard drive and the dvd drive.
After this if you turn it on and still don't get video then that means the motherboard is bad.
