2 IPL type PM4i installed on 2 different PC's
Same label software, same label design
Same XP version
On PC 2 output seize to large
on PC 2 label start printing half way the label
SW dump identical but for Media seize Printer 1, 2 inch
Media seize printer 2 1 Inch
On PC 1 driver installed 203 dots/inch
On PC 2 driver 1 install 300 dots/inch accidentily
changed back to 203 dpi (not uninstalled 300 dpi first)
Can you please give some advice?
Best regards,
Bram Derksen
Infor Global Solutions
The Netherlands
printer (Kit P/N 850-812-900 IPL Only), you must first
update the IPL firmware to version 2.74 or later."
I assume this is a partial exception to the general caution on page 1 of the same publication:
"When installing a printhead, make sure that the printhead
density and alignment is the same as in the one you replace
and that the printhead is designed for the type of printer in
which you are going to install it."
Also, the printer should not be powered when the printhead is being installed. The printer does not identify the printhead until it goes through a power-on startup.
