Check engine light will not stay off. only for about 20 miles..then comes back on ..need to smog!!!
SOURCE: I have a 2002 buick
One of the things you will want to check is your speed sensors, some times they will also cause your ABS light to come on, and they relate to your Transmission electronics that is why the Check Engine light comes on.
SOURCE: how to replace a coolant level sensor, 2000 buick century
The coolant level sensor is located on the radiator. If you are looking at the engine from the front of the car it will be on the left side. There will some kind of clip holding it in the radiator. Removed the clip and pull the sensor out. You will lose coolant so try to swap it out quick or drain some of the coolant out. Once new sensor is installed, install clip to keep the sensor in place and reconnect the wires to the sensor. Crank the engine and make sure the coolant level is full. This should correct your problem.
SOURCE: 2001 Buick Century I have a problem with
about $100, mostly labor on the dash illumination issue.
SOURCE: 1990 Buick Century 3.3L Check Engine Light comes on, stalls.
Need to check for fault codes. Possibly a faulty sensor causing the fuel system to run rich or lean.
SOURCE: check engine light comes on with codes PO401 &
P0401 sets when EGR flow test runs and fails. EGR may be moving too slow or not at all. May be a bad connection.
P0442 sets when vacuum decay test indicates small leak in the EVAP system detected during diagnostic test. Check for a loose or defective gas-cap. If the cap is fine it may be a false code or could be related to another EVAP component.
