I've checked the main fuse and it was fine. There are no lights of any kind working. I'm at a loss as to what to check next.
SOURCE: CBR 600 rr 04 lights and bike die when switched to high beam
There is a direct short in the bar switch or in the head lamp bucket check the wiring
SOURCE: 1997 honda shadow ace vt1100c2 ..starter switch, electrical
bad connection on starter or batt check bof of em
SOURCE: headlight won't work; all others do
Hi and welcome to FixYa,
Initially, suggested checks using a testlight (preferably, rather than a voltmeter) with the ignition switch ON:
Not to confuse you, the starter switch has an internal mechanism that switches off the headlight when starting. This is to ensure that the starter motor gets all the power from the battery.
Good luck and thank you for asking FixYa. Happy Holidays.
SOURCE: 1997 Honda magna 750 one seater needing two
You can fit two seats ,but it may mean that you will need extra fittings .Ask you local dealer if such fitting are avalable ,or you may be able to get some made .
SOURCE: i was out riding yesterday when all of a sudden my
the regulator only keeps the voltage regulated to about 13v charge for the battery no matter what speed you ride..if the regulator did not work correctly you might start to burn out light bulbs. So when you put in the new regulator make sure your battery is at least at 12.3v minimum if not you will have to push start it and ride it for about 15 minutes on an open highway to charge the battery back up to at least 12.6v-12.7v...13v is perfect. (if none of your other fuses blew then all other electrics should work), so i would double check all of your fuses just to make sure.
