HOW TO REFORMAT WINDOWS XP USING BIOS PHOENIX BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
SOURCE: bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
SOURCE: Unable to Acces BIOS on IBM Netvista 607931u w/ Phoenix ROM BIOS
When the IBM Setup Utility program prompt is displayed, quickly press F1.
The prompt is displayed for only a short time.
if you dont see the prompt, tap F1 repeatedly as the computer starts. If it says "starting windows" you've let it go too far and will have to restart again and repeat the process to get into the bios
REGARDS..
SOURCE: Dell Optiplex GX270 bios will not recognise
u will need to first update your bios and then reinstall dvd cdrw
SOURCE: Hi my name is jerry
I'm not sure if this will work for you because I haven't tried it but I trust these guys.
http://download.cnet.com/windows/keyboard-drivers/?tag=lia;rcol
I don't beleive this has Windows 7 support. What you can also tryis, click on "start", then "control panel". Find and right click on "device manager", open and click on continue. Click on the box(on right) next to "sound audio and game controllers". Do you see a warning, ?, !, or a yellow triangle. If you do click on that and follow proceedure. Right click on you Device(s) one at a time and you should see "disable". If you see "enable" click on that and exit. Right click on device again and click on "properties" then, on "driver" tab. Click on update driver, then on "automatically search for update....". When finished exit that. You should have a speaker icon in taskbar, lower right of screen. Right click on it then on "open sound mixer" and adjust volume.
