When i turn the key on lights come on radio comes on but the car does nothing no cranking no noises nothing is the starter bad
Is the car still in gear? If it is, then it will not start till you put the car in park. I've done this before and the same thing happened, had radio, lights etc...till I put car in gear and it started. Check the gear selector, if it's not in park, then put it in park and try to start. Hope that helps.
How old is the battery. This is the most likey cause. if you have a charger put it on the battery for a quick charge. Then try to start car. if this works replace battery.
SOURCE: car engine will not crank
on the starter there is a big battery cable and a small signal. wire connect a test light to the signal wire and try to crank the engine. if the light comes on then you will need a starter. be sure you have good connections first good luck.bye the way the light should only be on when you hold the key in crank pos.if the light is on all the time you are on the wrong wire.
SOURCE: 97 dodge neon died replaced parts and still no spark HELP.
YOU NEED TO CHECK DARK GREEN/ORANGE WIRE AT IGNITION COIL WHEN CRANKING ENGINE FOR POWER..IF NO POWER,SHUTDOWN RELAY IS NOT BEING ENERGIZED..THIS ENGINE ALSO HAS CAMSHAFT POSITION SENSOR ON END OF CYLINDER HEAD..ENGINE CONTROLLER NEEDS CAM AND CRANK SIGNALS TO ENERGIZE THE SHUTDOWN RELAY..UNPLUG CRANK SENSOR AND CHECK VOLTAGE ON ORANGE WIRE..SHOULD HAVE APPROX 8V..IF NOT..UNPLUG CAM SENSOR AND SEE IF 8V SUPPLY RETURNS..IF NO POWER TRY UNPLUGGING VEHICLE SPEED SENSOR LOCATED IN TRANS HOUSING WHERE RIGHT SIDE AXLE COMES OUT OF TRANS..IF 8V RETURNS..THE SPEED SENSOR IS SHORTED INTERNALLY..THESE 3 SENSORS SHARE THE SAME 8V SUPPLY CIRCUIT..WITH SPEED SENSOR UNPLUGGED,PLUG CRANK SENSOR BACK IN AND TRY TO START ENGINE..HAVE SEEN THIS SAME PROBLEM AT WORK RECENTLY
SOURCE: have a dodge neon 2000, the lights will turn on
starter may be bad have someone turn the key at the same time you tap the starter with a hammer it is right in front
SOURCE: Dodge neon 2001 will not crank at all. battery is
solenoid is part of the starter so best bet is to remove and have tested at an auto parts store.
SOURCE: no juice to the starter on a 2000 dodge neon,
Check the neutral safety switch,if it is good,replace the ignition switch,if all the fuses are good,please vote,thank you
turn key and nothing no clicks replaced radio and nothing removed radio and still nothing no clicks no crank
