Was using the unit and increasing the incline with the power went out. Replaced the fuse on the floor circuit (15a), and power is present on both sides, and the green light on the circuit board is lit, but still no power up. Help?
HOwever test the c. breaker and reset.
If the problem persist LUBE the deck belt+rollers bearing see the video attached.
see the diagram attached in case that you need to troubleshooting.
God bless you
SOURCE: Pro Form 745cs Treadmill does not incline
my sisters roller broke of the back end and detached from the plastic end can this be fixed?
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: Athlon iQ2 treadmill-just replaced motor control
If this is the same problem you had prior to replacing the MCB and speed sensor. I would check the drive motor, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) , if it does the check speed sensor to see if the correct spacing between sensor and front roller ( check if the magnet has not fallen out of front roller pulley this also can cause you problems) hope this help!!
