Raising the window shade cause the station to change.
Also the ceiling light no longer works. Happend with electrical storm
This problem sound like you have had some damaged to the earth ground in your electrical wiring system. You should have a electrician thoroughly test the electrical outlets and wiring in your house or apartment. You should be very careful using any electronic equipment with a problem like this. Your Clock/Radio should be unplugged from the a/c wall socket and the internal battery removed. This will allow the microprocessor that controls all the Clock/Radios functions to reset. The Clock/Radio should be left unplugged for a period of a few hours to discharge the microprocessor. This will help the microprocessor to heal itself from the lightning strike. You will need to get the ceiling light fixed. There might be a shorted wire or something causing its failure. This could also be a burnt wire. Lightning power overloads can be very dangerous to all electric and electronic equipment. Try putting your clock Radio on a rubber mat to isolate it from any traveling static electricity that may be in the air. Try to discharge any static electricity that may have built up on your hands by discharging it on a piece of metal like a screw driver or metal surface.Do this each time before you try to use the clock/Radios button functions. This will stop further damage from occurring during you handling of the Clock/Radio. After discharging the microprocessor, reassemble the battery into the Clock/Radio and plug in the wall socket. The operation should return to normal. If not you may have more serious damage to the microprocessor. You can call the Emerson Customer support at this telephone number 1-800-898-9020. Give then the make and model number of your Clock/ Radio and ask them for assistance. I hope this information helps you with your problem.
