Haier Energy Star ESA3183 Air Conditioner Logo
Posted on Feb 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed a new honeywell thermostat blows fan but will not heat
All wires connected. 4 wires R, W, Y, G. programmed but no heat.
  • Ken Bledsoe May 11, 2010
    What color wires went where?
carl carpenter
Level 2:
  • Expert 82 Answers
  • Posted on Feb 08, 2009
carl carpenter
Expert
Level 2:
Answers
82
Questions
0
Helped
86515
Points
208
Make sure jumper is installed between rh and rc
2answers
WHERE I CAN BUY A THERMOSTAT - Honeywell T6575D1009 thermostat
Honeywell T6575D1009 - Digital Fan Coil Thermostat
www.supplyhouse.com > Honeywell-T6575D1009-Dig...
Honeywell T6575D1009 - Digital Fan Coil Thermostat; 4 pipe Auto Heat/Cool changeover, 3 speed fan with On-Auto Fan switch - Overview T6570 Series Digital ...
www.ontimedirect.com > t6575d1009-thermostat
Honeywell T6575D1009 Thermostat. This item has been replaced by TB6575A1000, which is a functional replacement. See the suggested products field for a ...
T6575D1009 Honeywell Electric Thermostat-NECC
necc-controls.com > t6575d1009-honeywell-commercial
Honeywell T6575D1009 NECC offers Fan Coil T/S Auto C/O.
Honeywell T6575D1009 120v Thermostat ' Heating, Cooling ...
www.kijiji.ca > ... > Home Renovation Materials
Send me any offer. Delivery and instal available for a small fee. Slight used, works and good condition. Digital Fan Coil Thermostat; 4 pipe Auto Heat/Cool ...
Honeywell, Inc. T6575D1009 T6570 Series Digital Fan-Coil ...
controlscentral.com > tabid > ProductID > honeywell-t6...
T6575D1009 T6575D1009, Honeywell, Inc., Digital Fan-Coil Thermostat/2 or 4 pipe heat/cool Digital Fan-Coil Thermostat/2 or 4 pipe heat/cool.
I installed a new thermostat on my hvac system and the heat is not working anymore.
On that thermostat there is an R and an RC wire connection, the R is the power wire for heat and RC is the power wire for cooling. If you connected the power wire (normally red in color) to the RC only the fan control and AC control will work, there has to be a jumper wire between the R and RC terminals (assuming there is only one control transformer) for both the heat and cool functions to work.
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
I am replacing a 10 year old Honeywell Thermostat with a mercury switch with a new programable digital Honeywell OS#RTH7500D1007 MD 0638. There a 4 wires coming out of the wall and are installed on the old...
You are on the right track, you can hook the same 4 wires to the new thermostat without the jumper you had on the old thermostat. The jumper wire that is on the new thermostat can stay with no problems. Just connect the wires to the same terminals on the new one and your good to go!
1helpful
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
2helpful
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Im changing an old honeywell thermostat with a new honeywell thermostat. the old on has wires 4 wires connected to 4 screws C,R,G,W but the new thermostat has a place where the wires go which are...
Yes, I believe that you will be fine. If the original wiring is correct then I have listed the basic wiring below. As always read the directions and make sure the wiring matches your system.
Red wire = Rh (24v power, should have an exsisting jumper to RC)
White wire = W (heat mode)
Yellow (or sometimes blue) wire = Y (A/C)
Green wire = G (Indoor Fan)
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
