I just bought a Palm TX (OEM) from a 3rd party. I can only use the buttons to open programs and navigate. When I try to use the touchscreen for an entry or to enter a memo, etc. nothing happens.
Search youtube for Palm TX Digitizer Replacement and Palm TX Take Apart Direction. If you think you can do it, or know someone who can, you can order a replacement digitizer on ebay for from somewhere like www.pdaparts.com.
Before ordering the part, you may want to start by opening the palm and cleaning the connecting ribbon cable contacts to make sure that a loose cable or oxidation has not caused your problem.
I have a similar problem, the unit is practically new, and I have a hard time with the screen not being sensitive enough. Would the previously stated solution be the same for my case?
When I try press on some area on the screen, the unit seems to register somewhere higher than where I pressed. If I press near the bottom of the screen it registers fine, but when I press higher and higher on the screen it registers further and further up. :(
