Juki MO-655 Mechanical Sewing Machine Logo
Posted on Feb 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Juki MO-2516N motor runs in reverse
How do i change the direction that the motor is running?
SewTechWayne
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Expert 186 Answers
  • Posted on Feb 01, 2009
SewTechWayne
Expert
Level 2:
Wolfpack:
Answers
186
Questions
0
Helped
73850
Points
377
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
  • TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
    hi there
    if you are use machine with clutch motor this way to change direction
    1 - trun power off and wait until your motor descharge from electricity and unplug the plug from motor saide and make full turn and plug it again - turn machine ON and test direction.
I have a brand new Juki MO-6704S at the shop but it is running backwards. The only manual I have only showing some basic settings but not troubleshootings. How can I switch it back to normal?
Sometimes machines will run backwards if the plug is reversed. Since you just purchased it, take it back to the shop and have them look at it.
Ask some of your co-workers or manager to help you.
Serger motor locked up completely
I suggest taking the machine in to be serviced
I want to adjust my serger yuki mo 2516n but i don't still have it's manual instructions
if you go to this page http://www.juki.co.jp/household_en/serger/index.html there are the current household sergers from Juki and a four page threading diagram for them showing the different stitch set ups.
If your serger is a domestic one too (the MO in front makes me think so) then you may find that the threading up is very similar on your model. Stitch length is usually a kob on the right marked from 0.5 to 4 and differential feed knob is usually there too, usually marked from -0.5 up to 1.5. Tension settings are usually around 5 but you adjust the looper tensions to suit the fabric and how wide you are trimming it with the blades.
You could contact Juki or their local distributor in your country and arrange to purchase manual for your model. http://www.juki.co.jp/household_en/dl/index.html this page gives a listing for countries.
it is also available on line to purchase as a black and white pdf file, http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/MO-2500_Instruction_Manual.htm for $8USD
I have Juki ddl5550 model cs-4002-6 that the
It might be your connections inside, Juki is a great mechine I would fix it.
call 303 770 6321
AAAA TEVA
We have a Juki MO 804 Overstitch/serger machine, while it is turned on but not sewing the motor makes a squealing noise like a slipping belt. Is that what it is or should I worry about something else
if its on and not running then its most likely a motor bearing or an incorrectly adjusted clutch ( large bolt on the right side of the motor ,from front of machine) loosen lock nut ( 17, or 19 mm) and adjust bolt until the noise goes away.
3helpful
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
