20 Most Recent Juki MO-655 Mechanical Sewing Machine Questions & Answers
3answers
How to adjust the stich lenght on a juki ddl 553 strite stich.
I still don't understand this. I have acquiured a juki DDL 553 recently to discover I have no idea how to change the stitch length and that there is no reverse stitch. I have pressed the black button and have tried to turn the side?( the wheel?) but when i push down on the black button there is no way to turn the wheel it doesn't move, maybe there is some other part I'm supposed to be moving??
12/7/2020 3:03:21 PM • Juki MO-655... • Answered on Dec 07, 2020
Where can i download free of charge service manual
You can download a PDF copy on this site~
10/3/2014 9:50:42 PM • Juki MO-655... • Answered on Oct 03, 2014
What size of neddles do I need for a juki MO2416N
The actual size needle depends on what fabric you are sewing. Lower numbers for light fabrics and higher numbers for heavier fabrics. I use mainly 10, 12 and 14 for normal cottons.
5/29/2014 11:06:22 AM • Juki MO-655... • Answered on May 29, 2014
Motor stopped; locked handwheel
Remove the needles. See if the handwheel moves now. Since it's a new machine, consult with the seller.
5/26/2014 3:27:18 PM • Juki MO-655... • Answered on May 26, 2014
Door sensor problem on juki 655
you have to get the door fixed, juki is set up to power off if the door is open for safety reasons
12/10/2013 4:29:13 PM • Juki MO-655... • Answered on Dec 10, 2013
Attaching the cover stitch plate
The extension plate must be easily removed,
therefore has to be easily attached.
Usually they are slided in from left to right.
If you can upload a picture of the extension table, may be I can help you more.
11/4/2012 8:32:52 PM • Juki MO-655... • Answered on Nov 04, 2012
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning. Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
9/3/2012 8:33:53 PM • Juki MO-655... • Answered on Sep 03, 2012
I have a Juki MO-655. I just threaded the machine,
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
9/2/2012 7:38:54 PM • Juki MO-655... • Answered on Sep 02, 2012
My thread keeps ripping on my juki mo.2416 how can i fix the threading
try changing the needlecheck for burrs
5/21/2012 7:54:04 PM • Juki MO-655... • Answered on May 21, 2012
Im trying to figure out
My manuel says all tensions should be at 4.
8/17/2011 2:24:51 AM • Juki MO-655... • Answered on Aug 17, 2011
My machine just locked up
These machines have many lubrication points. Any place where metal to metal rubs together creates friction, and should be lubricated. But when these machines lock up, most of the time it's the feed cam that has seized. This is located on the left side where the stitch length assembly is. There is usually a large black straight slot screw right in the middle of the cam. Sometimes a plastic cap with a red arrow on it is glued to it. That just peals off. You pretty much have to replace these two pieces because what happens is that the pot alluminum swells up and then no longer turns freely in the ring any longer. A few things have to be adjusted when this is taken apart. Might be a shop job.
4/27/2011 7:22:31 AM • Juki MO-655... • Answered on Apr 27, 2011
HOW DO I THREAD THE JUKI MO 2416N
HI THERE
CAN YOU PLEASE EMAIL ME ? I CAN SEND THREADUNG DIAGREM FOR THAT MODEL.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
[email protected]
3/13/2011 7:30:13 PM • Juki MO-655... • Answered on Mar 13, 2011
Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
10/28/2010 12:15:28 PM • Juki MO-655... • Answered on Oct 28, 2010
2answers
How do I time a Juki 5550? Never done it before,
Having the suggested hook position from the manual is very desirable. Can be easy. Loosen screws holding hook assembly in place. Position needle on upstroke and position the hook just above the eye of the needle then tighten the screws on the hook. Should be close. Call Juki and they will email a tech manual to you. Good luck.
7/6/2010 8:26:31 PM • Juki MO-655... • Answered on Jul 06, 2010
Juki MO-655 Mechanical Sewing Machine Logo
Popular Tags
38 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
size neddles need juki mo2416n
  • Sewing Machines
