S Video cable from LAptop to TV , (RED, YELLOW, WHITE )
Even after connecting S Video cable from Copmaq Presario Laptop Output to TV, with Red, Yellow, White towords TV end, No picture. I tried pressing FN/F4 many times, On TV side i have selected AV2, checked the AV2 port from other source (DVD output) it works fine, so no problem with TV, AV2 port.
What could be the problem in LAPTOP, is there any settings?, Is there any drivers missing?, pls Help Thanks
Generally TV takes RCA Cable. So You need two cable one for Video i.e. VGA to RCA Cable and another is 3.5mm Pin to RCA.
In RCA Yellow Pin is for Video so from VGA to RCA cable Connect Yellow Pin to TV and Red and White pins are for audio so connect white and red pin from 3.5mm Pin to RCA cable.
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
You must have a monaural (mono) TV even though it looks like you have speakers on each side. The VCR has stereo audio output red=right white=left yellow=video. Ideally you would buy a mixing tee to add the left and right signal. Or if your VCR supports it you can set it to mono output. Otherwise, just use the white (left) cable to feed the mono input (white) and of course the yellow to yellow for video. Just ignore the red wire or lightly tape over it to avoid any short. Best,
-Ken
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
U need a S-Video cable for the video output, and for sound u need a plugin to RCA cable, its the one that on one side looks like its for headphones and the other side its 2 cables, red and white like the usual we use for dvds
you can get s-video to scart connections;and if youve no scart you can connect s-video to phono....thats ur red,yellow n white audio / video plugs.yellow=video...white/red=left/right audio.
if you download a service manual it shows the pinout for s-video connections making it able to connect phono's.you only need the yellow and either red or white cos pc only outputs mono to tv.
there are also wireless systems you can get though never tried them.
you could also connect to another monitor,just plug the monitor into the back of pc(ext)only go into on place one way so no prob there.if no picture on ext monitor u need to switch screens
(alt+f 4)usually.press together once switches to ext mon,press together again enables both screens,and again returns to pc.
