Please advise if you are able to provide via email, a manual or instructions on how to programm this scanner
We have the frequencies, however no actual instructions about input and saving the information
Thankyou
regards Mike & Lisa
Why has my uhf cb radio transceiver jammed on channel 3?
Hi Mike & Lisa,
From what I have been able to find, the N32 is a scanner released by Uniden for the Australian market. However, as I am sure you already found, there is no reference to it on either Uniden's US or Australian sites. However, it appears that the N32 has an identical keyboard layout to a scanner released in the U.S., the BC60XLT-1. Hopefully the manual for that scanner may help you with the N32. The link to the BC60XLT-1 manual is:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
While this may not be a perfect match, I hope it helps get you up and running.
Also, one thing to keep in mind...different frequency ranges are used in different areas of the world. If you are using this radio in the U.S., the frequencies you want to program may not be within the limits of your scanner. Since I don't have the manual for your specific scanner, I have no idea what those frequency ranges are. You may just have to "trial and error" it.
Good luck! I hope this helps get you up and running!
Here's a link where you can download and print the full owners manual for your scanner:
http://uniden.com/pdf/BC72XLTom.pdf
Bill B.
keeping getting error every time program it
can not program scaner to police codes, only get static, i have a unidenbc72xl
cant program to local frequencies. please email [email protected]
